Rear Trailing Arms for Toyota MR2 1989-1995 SW20
The MR-Platform is difficult to master due to the sensitivity of weight-transfer which can cause the car to seem unstable; because of this fact the alignment is absolutely CRUCIAL in this vehicle and can greatly effect the stability and handling.
Megan Racing Inc. has developed reinforced and adjustable control arms to accomidate the needs of the aggressive and performance oriented tuner. Being constructed of a Lightweight Steel-Alloy which is able to withstand the stresses of extreme competition, these arms are powdercoated with a 3-Stage process to ensure durability and protection against the elements.
These Traction rods allow for fine-tuned adjustments to the rear suspension geometry. By changing the length of the traction rod you change the position and pitch of which the suspension rotates upon and you change the amount of "Anti-Squat" of the rear. Although the adjustment is minimal, it can change the behavior or the vehicle during weight transfer.
- Constructed of Steel Alloy for Lightweight yet Durable performance.
- Teflon-Injeted Heim Joints for a more direct feel and driving experience.
- Easy to access turnbuckle-style adjustment.
- Can be adjusted without removing from the vehicle.
Pris: 1800kr för bägge. Kan givetvis skickas från Borås.
