tjena igen.
nu tar vi nästa problem, ABS:n.
Kollade fel koder fick felkod 33 och 35.
Någon som vet exakt vad dom betyder, lr har en bra länk så man kan kolla.
tack på förhand
Fel koder. Toyota Camry 2,2i 95a
toyotasankey
- Bilmodell: Toyota Camry 2,2i
- PierreW
- PostOrt: Borgstena (Bôsht)
Re: Fel koder. Toyota Camry 2,2i 95a
Du får resistansmäta givaren, är 99%säker på att den är trasig, brukar rosta runtom tills den blir såpass ihoptryckt att den går sönder invändigt.
Google gav mig detta på 10sekunder
11 — Open shorted relay circuit. Check modulator wiring harness, solenoid relay, solenoid relay wiring harness and solenoid relay connector.
12 — Short in solenoid relay circuit. Check modulator wiring harness, solenoid relay, solenoid relay wiring harness and solenoid relay connector.
13 — Open pump motor relay circuit. Check modulator wiring harness, pump motor wiring harness, pump motor relay circuit and pump motor connector.
14 — Short in pump motor relay circuit. Check modulator wiring harness, pump motor wiring harness, pump motor relay circuit and pump motor connector.
21 — Open or short in ABS solenoid for right front wheel.
22 — Open or short in ABS solenoid for left front wheel.
23 — Open or short in ABS solenoid for right rear wheel.
24 — Open or short in ABS solenoid for left rear wheel.
31 — Problem in right front wheel speed sensor circuit.
32 — Problem in left front wheel speed sensor circuit.
33 — Problem in right rear wheel speed sensor circuit.
34 — Problem in left rear wheel speed sensor circuit.
35 — Open in left front or right rear wheel speed sensor (WSS) circuit.
36 — Open in right front or left rear WSS circuit.
37 — Faulty rear speed sensor rotor.
41 — Battery voltage too low or high (under 9.5 volts or over 16.2 volts). Check battery and charging system.
51 — Pump motor is locked or pump motor circuit is open. Check pump motor, motor relay, wiring harness and modulator ground connections
Höger bak.En sån har jag liggande pga felköp (passar inte Celican
500:- så är den din.
toyotasankey
Johnny Blade skrev:Höger bak.En sån har jag liggande pga felköp (passar inte Celican).
Är det den så köper ja den direkt. Ska ut å kolla skiten nu
Sitter den "kontakten" inne i bilen lr??
Pugho
- Bilmodell: Celica GTi
- Årsmodell: 1991
- PostOrt: Eskilstuna
Kontakterna till baksensorerna ska sitta inuti bilen om jag inte minns fel.. Under baksätet typ..
____________________________
Mikael Cedergren
Mikael Cedergren
