1984 Celica Supra MA61
Vice Ordförande
Re: 1984 Celica Supra MA61
Inlägg av Bempa » mån 02 feb 2015, 19:53:32
Nicely done on the rust!
ST165 3sgte Brum Brum
Christoph
Bilmodell: Celica Supra MA61
PostOrt: Göteborg
Inlägg av Christoph » tis 03 feb 2015, 11:37:58
Thank you :)
It has been a lot of work on the rust, but we have only repaired the most necessary areas. There is a lot more work to do...
It´s a 5M-GE, the 170hp version without EGR and cat. :)
Unfortunately right after i arrived in Gothenburg the headgasket broke and its running on 4 cylinders now... but its still running smooth and quite strong :)
Headgasket set, head studs and other bits are ordered already... it should be fixed in a few weeks...
Muda
PostOrt: -
Inlägg av Muda » fre 15 jan 2016, 22:24:44
It's actually not that much work involved exchanging the gasket itself. According to Toyotas flat rate times it's a 5-6 hours job. Did it on my 5ME (main difference is one camshaft and timing chain instead of belt). Way more time consuming doing a swap, unless your going for the 6M that is...
