1984 Celica Supra MA61
Christoph
Bilmodell: Celica Supra MA61
PostOrt: Göteborg
Inlägg av Christoph » sön 25 jan 2015, 14:36:41
Hi all,
I am sorry for writing in english, I just moved to sweden and still have to learn swedish.
I am from Austria and own a 1984 Celica Supra, partly restored a few years ago.
Two weeks ago I moved her with me up to Sweden.
Now I have an issue and would need a trustworthy workshop or mechanic in or near Gothenburg to get the headgasket fixed. Can anybody help me with that?
Thanks a lot
Christoph
Re: 1984 Celica Supra MA61
Inlägg av Glenn » mån 26 jan 2015, 00:55:30
Wecome to Sweden, and TCS :)
Hopefully someone near gbg can help ypu with a recommendation for someone to rebuild your engine.
Christoph
PostOrt: Göteborg
Inlägg av Christoph » tis 27 jan 2015, 12:31:21
Thank you! :)
Actually I am working in Gothenburg for almost a year now based on business trips, but now as I moved here completely things can only get better :)
I will upload some pictures of the part restauration of the Supra soon that I did 5 years ago.
She was sitting in my garage for three years untouched because I was always on business trips and did not have time.
Cleaning and greasing the brake mechanics was actually all that had to be done to get her back on the road.
After a few kilometers to check everything I started the trip up here and further to Norway for an Ice drift event. Unfortunately after 3000kms driving and checking oil and water levels regulary it seems that the cooler cap broke and there was no pressure on the cooling system anymore. I guess thats the reason for the headgasket to fail.
Actually she is driving and working without smoking but less power and the 3rd and 4th cylinder have no compression...
Zoomorphic
PostOrt: Sverige
Inlägg av Zoomorphic » ons 28 jan 2015, 11:43:11
I would recommend to buy another engine to swap fast, just the cost for labor is going to be massive if you are going to have a mechanic to do it. If you havent good pal where you can work and just swap the parts you need.
Regards Michael
Bygger hellre än kör!
Christoph
PostOrt: Göteborg
Inlägg av Christoph » ons 28 jan 2015, 12:41:17
I fear that it will cost a lot... Its not the cheapest country to have repairs :D
I have a very good friend who could do it, but he is near Oslo unfortunately...
But your point raises another question... I need to register the car in Sweden... How big are the possibilities to get another engine, i mean not a 5M, but a JZ engine, legally registered in that car here in Sweden?
Inlägg av Glenn » ons 28 jan 2015, 17:00:08
I would try to register the car with the current engine, and then swap it later if you want to swap to another type.
The guys that doing registration is MUCH better at spotting modifications than the guys that do the yearly check ("besiktning")
With that said, it is possible to do legal engine swaps if some things are fulfilled, and since this car is pre 1989
(1989 was the year all cars had to use catalytic converters) you maybe even could use a special rule that say that you
can upgrade older cars to cat, and then you should move the engive from a newer car including all the exhaust gas control system
and then you dont have to pass as much rules to get it legal. ..I think that you are also allowed to raise the power in
the engine slightly doing this swap, 10% or so.
If you are lucky you can also register the car as "flyttgods" if you move to sweden, but its not as useful as it used to be..
Christoph
PostOrt: Göteborg
Inlägg av Christoph » ons 28 jan 2015, 18:17:40
I thought so already... Just the people in Norway keep telling me that its so much easier in sweden to get modifications legal, so easier does not mean exactly easy ;)
10% more power would be legal to get? Then even a 7mge swap would be too much already...
It was my plan already to get the registration with the car being completely original and doing modifications later, now I just have to find someone to repair the headgasket...
What about suspension or brake upgrades, are they strict there?
Zoomorphic
PostOrt: Sverige
Inlägg av Zoomorphic » mån 02 feb 2015, 12:29:51
Brakes and suspension they dont really care about, as long you havent changed the car so much that you disrupt the collision zones. But then you have to weld and modify alot! There is alot of laws preventing you doing anything on the car but here in sweden they dont really care, as long you dont have huge amount of power in the car and in the registration papers it says otherwise.
Regards Michael
Christoph
PostOrt: Göteborg
Inlägg av Christoph » mån 02 feb 2015, 12:34:42
Its time to introduce it a bit more :)
I bought it in 2008 in a very bad shape, 8 preowners and a lot of abuse...
It took me 3 Years to find a garage to work on it and I had another project in the meantime aswell, an R33 Skyline for drifting...
So in 2011 we did a "fast" fix to bring it back to the road, it should have been just welding a few bits and getting the suspension, brakes and engine back to work... In the end it was a bit more work than expected, as usual ;)
Thats how it started:
At some point a lot of the car looked like that:
And it started to look like a car again:
One fender was repainted really bad so there was surface rust everywhere... simple solution to fix it:
And it got more and more into shape:
After the paintjob it looked nice again:
And that was the final result, although it looks better in the picture than it is and as it is meant to be driven and not a beautyqueen it already has some bad bits all around again. But still a great result:
Inlägg av Johnny Blade » mån 02 feb 2015, 17:39:24
Great work (bean there,done that :) ) :thumbup:
Does it have 5M-GE?
